  • 8 Vote(s) - 3.25 Average
which suspension / front end swap?
hi there all. just got my 2nd partner :woop: is an old 97 1.8d in pink/white/red montage haha
couple of things i wondered, is the front suspension the same as the 306? or is it "higher". ie, if i were to fit some -30mm springs from a 306, would the drop be the 30mm or would it be more due to the already lower height of the 306... or is it the same?
also, i wondered if the phase 2 front fits onto the phase 1 van? it looks like just a simple facelift and as such seems like it would be a straight swap, but these things are never as simple as they seem Confusedcratch:
thanks Smile
anybody got any ideas?
No idea, sorry.
I DO MISS MY BERLINGO Heart
Thk it can be done chk my posts i converted a 2001 transit to the latest 2010 shape
[-] The following 1 user says Thank You to muply for this post:
  • OcaToro
306 Coilovers bolted straight onto my Partner, so I guess the struts and springs are the same, but TBH I'm not sure if theres a ride height difference (forgot to measure mine..doh!)
'04 Peugeot Partner HDi LX. Lows, Leaks and Wellers. Now matt grey and dent free Smile
[-] The following 1 user says Thank You to PeteA for this post:
  • OcaToro
306 and picasso are the same if you put the 30mm springs on it will be 30 mm lower but cos the partner arches are bigger your van will not look that low. If your going coil overs bye the Picasso ones because the the shocks are the same as the partner and 306 rear shocks are smaller. Hope this helps
120mm lowered on coil overs 7x7.5 lenso wheels metal number plats exhaust strut brace front splitter HIDs m3 side skirts Renault
Megan front splitter tinted windows half leather seats momo steering wheel short shift twin edge 1800wts subs roof lining front and back
[-] The following 2 users say Thank You to Eurolee for this post:
  • Kokain, OcaToro
so do you mean the front wings are different between the berlingo and partner on a 04 model
Further from the posts above, Has anyone tried either 306GTi-6/Rallye front springs/shocks or Xsara VTS front springs/shocks? I have a set available that I was thinking of putting on, Im not really that interested in what it looks like (ie- I dont have any desire to 'slam' the van) but want to get a more positive driving experience and upgrade the front end to match the 405 MI-16 rear beam I have ready to put on(Yey! Disks, ARB and stiffer torsion bar!).
In addition, anyone have any experience of upgrading the ARB at the front- again, I have access to both a xsara VTS and a 306 GTI-6 one- again, seeking a better driving experience!
FINALLY, anyone shortened either of the quadrants on the gear linkage to give a short shift? As far as Im aware its basically the same as doing it on a 205 or 306- but was just wondering if anyone had done it and worked out some measurements?
Cheers!
Chris
Yesterday 08:03 AM
Last Post: RMSSA
22-09-2026 08:52 AM
Turbo lag 1.6HDi
Last Post: Westy
21-09-2026 09:07 AM
16-09-2026 09:50 AM
» Replies: 16
removing front strut
16-09-2026 02:07 AM
Strut Top Mounts
15-09-2026 07:58 PM
