Threads: 4
Thanks Given: 5
Hi, just recently my 04 forte berlingo has been a little bit laboured when starting from cold in the morn. Also there is quite a bit of smoke when it finally starts? Any ideas please:S. Also, when i open the boot something clicks within and locks itself when it returns to the latch, so i have to lock all the doors to open it again:brickwall:....
Other to that its a beauty!! Cheers guys and gals
Threads: 32
Thanks Given: 18
1.9d 2.0hdi petrol?
Threads: 32
Thanks Given: 18
Could be valve clearances, what mileage is it at?
Threads: 20
Thanks Given: 2,126
18
Check glow plug operation & as Steve says,valve clearances.Good luck.
Strawberry flavoured windows
Threads: 32
Thanks Given: 18
It won't be glow plugs, they only operate when it's zero degrees.
240k? Wow!
Threads: 21
Thanks Received: 36 in 34 posts
Thanks Given: 6
08-04-2012, 10:10 AM
(This post was last modified: 08-04-2012, 10:11 AM by muply.)
Mine only starts after glow plug light goes out Steve had new plugs fitted 8 weeks ago
wd40 on boot lock mite solve the fault
Thanks Received: 17 in 13 posts
Thanks Given: 10
I had the same problem on another motor, new glow plugs cured it.
I was also told glow plugs always come on before starting unless the engine is still warm, nothing to do with the outside temp.
