  • 15 Vote(s) - 2.87 Average
petrol in my hdi!!
hi i pulled in garage and when i was thinking robbing sods at 1.49.9 per ltr i put 2 ltrs of petrol in before i realised. hoo noo! what a dope. the tank is full so do you think it will do any damage. 2.0hdi. it is running well at the moment.
Just keep topping it up to max with Diesel and should be fine.
[-] The following 1 user says Thank You to taxi for this post:
  • ron
Taxi is right, nothing to worry about with such a small amount.
*I did it too*
If it were Diesel into Petrol then it a different story, tank has to be drained and cleaned out.
My mate filled his Petrol Picasso with Diesel and discovered that there is a safety cut off fitted to Citroens that prevents engine damage if wrong fuel detected.
woodshaper
Sole Member and President for LIFE!
[-] The following 2 users say Thank You to woodshaper for this post:
  • ron, taxi
I heard of a Partner that was filled 75% with petrol. It did not like starting and low RPM but once it was reving it was ok. Would not start one morning but " Breakdown Service " bled it and it started. they never noticed it was a diesel with petrol in it ! Just kept filling with diesel and eventually it was to all appearances normal. :whistle:
The main problem with petrol in diesel is Diesel Fuel lubricates the pump, pump valves and injectors, petrol washes away that lubrication accelerating wear and making them run hotter. petrol can also damage seals which may be incompatible, the same applies to some " alternative " diesel fuels
Different manufacturers quote different acceptable diesel /petrol ratios.
Petrol does not float on diesel despite being less dense, it mixes.
A small amount should have negligible effect just keep topping up with diesel to reduce ratio as quick as possible. Smile
thanks lads you have cheered me up. im glad i realised quick or it might have been a bit nasty. thanks for your replies.
It will just decoke your engine so it will prob not smoke that much now lol
120mm lowered on coil overs 7x7.5 lenso wheels metal number plats exhaust strut brace front splitter HIDs m3 side skirts Renault
Megan front splitter tinted windows half leather seats momo steering wheel short shift twin edge 1800wts subs roof lining front and back
lee maybe i should put some more in then. lol.
Best stick some in mine then lol
Hahaha
Mines ok dont smoke one bit Lee are you tinting your headlight mate
Rear seat belt breakage
Last Post: Mad one
Yesterday 06:09 PM
Yesterday 05:49 AM
11-09-2026 11:36 PM
07-09-2026 09:06 AM
Last Post: BDRichardson
06-09-2026 04:07 PM
Last Post: kulat
03-09-2026 09:59 PM
31-08-2026 08:50 PM
29-08-2026 08:39 PM
29-08-2026 08:26 PM
29-08-2026 05:45 PM
