  • 7 Vote(s) - 2.86 Average
Airbag lights ???
I would like some info if i may?
When i purchased my Berlingo a few weeks ago, the airbag lights where constantly illuminated on the dash, i did not take any notice as the car started etc. But after reading on here that this may cause an M.O.T failure:S.
I noticed on the side of the dash when you open the drivers door, that there is a key like bit with the words " airbags off (to the left ) and on (to the right)". This is switched to the off position. Can i turn it or should i turn it to the on pos, if so what kind of key is this?
Can i just disconnect the airbag light ????
Please helpSmile
Should be ignition key mate would try it no harm will be done
Also try having a fiddle (ignition off!) with the wires/connectors under the driver's seat - on mine and several others it seems the contacts are a bit temperamental and just wiggling them around a bit can clear the airbag warning when you next start.
ISTR that airbag key control is so that you can switch the passenger side one off when a childseat is strapped onto the passenger seat - it's in the manual somewhere.
Think u can make a short circult under seat with a piece of wire between the two pins
will give it a go and let you know!! Cheers, guys
If you turn the passenger air-bag switch to 'On' the warning light will go out,
assuming no fault with the air-bag or connectors. HTH!
did it sort it
No, switched the air bag to on, still no joy!
Looked under the seat, to my amazement there is a cd multichanger there...... no cartridge tho, there were 2 jacks there, wiggled them around but light still stayed on. Shall i pull them out and squirt with wd40 ??
Hi Rob and I presume Tubby is keeping an eye on this thread :wave:
What I can tell you is that my van has passed two MOT's with the airbag warning light on and it wasn't mentioned at either station :thumbsup:
I hadn't given a thought to this being a possible cause for concern at next MOT either , untill I read this thread :S :eek:
Hi, unplug/plug the connectors under both the front seats, these are for the seat belt pretensioners and will cause an airbag fault.
Don't forget to do a shut down procedure and disconnect the battery before working on the air bag system!!Confusedillyme:
Let us know how you get on:thumbsup:
Today 05:26 PM
Air filter box removal
Last Post: Harrythephot
Yesterday 11:03 PM
Berlingo undertray
Yesterday 08:56 PM
» Replies: 23
06-03-2026 10:10 PM
» Replies: 21
06-03-2026 04:25 PM
06-03-2026 07:07 AM
05-03-2026 08:16 AM
03-03-2026 06:17 PM
03-03-2026 07:57 AM
02-03-2026 02:51 PM
