  • 19 Vote(s) - 3.21 Average
1.6hdi camshaft sensor replacement
right. costs about 38 euro for the sensor
its located on the back left of the engine bay, under where the egr outlet meets the inlet manafold.
take out the 2 hex screws holding the egr pipe. you need to bend it out of the way. i stuck a spanner in to keep someway clean. dont go mad its just to give ya room to get a hand down
its held on with one more hex screw. dont disconnect the sensor untill you`v wiggled it out,
same again when putting the new one in, connect it first, stops it falling down if it slips.
get it in position before you screw it down, and make sure its pushed in before final tighten.
screw the egr pipe back. i found it easyer to push it into position first then get a screw started to hold it
Nicely detailed post. Thanks. But, being very naive about modern autos why did you need to change the camshaft sensor (I didn't even know there was one)?? What symptoms are exhibited by a faulty sensor? Thanks.
3 times it just shut down, no sputtering or attempt to keep going just stopped.
Wouldn't start until the van shut down completely, (after 5 mins of the key being taken out there's a click noise and everything shuts down)
Then it starts perfect. My thoughts is when the sensor misreads it shuts down the engine to prevent engine damage if it had a camshaft failure and won't restart until the Ecu resets.
I pinned it to the camshaft position sensor with the plug in computer, it showed a saved fault for the sensor[/u]
[-] The following 1 user says Thank You to corkgsxr for this post:
  • 3rensho
Thanks for the explanation. I learn something every day.
SOLVED: P20F6 fault
Today 07:18 AM
Coolant
Last Post: Martinze
Yesterday 08:24 PM
Leaking windscreen or aerial
15-04-2026 08:50 PM
