LWB simple conversion
I'm planning a basic table / bed conversion similar to a boot jump, so that I can easily remove it when not in use.
I've noticed that most of these type of conversions has a fairly short bench on either side with a largish full width section behind the mid seats.
I'm considering making the benches longer on either side (almost up the the rear seats) so that there is a larger table.
Can anyone think of why this might be a bad design?
If table is too big it could get in the way in what is not a big space. That said you are using a LWB so will have much more room than my Mk1.The short table should be enough to pivot round if you are sitting over the back seats. I made sure that the table leg is almost in the corner to give greater flexibility.
Not convinced that the standard design of a bench either side in boot is all that useful as it is very cramped and the footwell ditto. I went down Gravity's design route making the non drawer side bench foldable to give more footspace.
Berlingo M59 is the modern 2CV - practical no nonsense motoring!
Last Post: ADarkDividedGem
Yesterday 10:25 AM
08-06-2026 11:13 AM
Last Post: TGD
06-06-2026 09:50 PM
Last Post: CB-K9murph
05-06-2026 05:47 AM
03-06-2026 06:47 PM
Fuel pump problems
02-06-2026 07:07 PM
Last Post: Desdinova
27-05-2026 10:15 AM
Last Post: Stevie3393
25-05-2026 12:34 PM
24-05-2026 12:57 PM
Rattling calipers
Last Post: Chrisfox1975
24-05-2026 10:47 AM
