2009 Berlingo Non Start anti Theft Active
Hi All
I have a 2009 Berlingo 1.6 Hdi non start - Anti theft active
Faults Codes
BSI Fault Code F4BA - Immobilser fault
All other modules have no faults detected
I had the key tested by a locksmith which is working fine
I have changed the ring around the ignition
Still transponder not detected
The only thing that the van is doing strange is bringing on the Dip beam as soon as the ignition is turned on ( the relay in the BSI clicks as soon as the key is turned on )
Have done the BSI reset which has made no difference
Dont know what to do next, all fuses are OK
Appreciate any advice
(22-11-2023, 05:41 PM)ringo981 Wrote:  Hi All
Faults Codes
Don't know what to do next, all fuses are OK
Is the car battery OK? A failing battery on the Berlingo can give all sorts of weird faults.
_______________
Not a Citroen  Cry
2008 B9 1.6Hdi Multispace XTR
2002 Xsara Picasso 2.0Hdi
1996 ZX 1.9TD Estate
Faults Codes
Hi
Thanks for the reply
The BSI unit is faulty as well as the high prerssure fuel pump
Mileage
Yesterday 04:33 PM
eolys
Last Post: magoo1
19-05-2026 03:02 PM
Rattling calipers
18-05-2026 05:36 PM
Yet another ABS fault
13-05-2026 05:57 PM
11-05-2026 09:17 AM
03-05-2026 01:27 PM
Head unit quad lock
03-05-2026 11:17 AM
Spare Key Fob?
29-04-2026 08:05 PM
29-04-2026 06:27 PM
Eolys problem
24-04-2026 07:07 PM
