  • 11 Vote(s) - 2.73 Average
Electrics dead as dodo
All electrics totally dead - worked fine yesterday until got home when started beeping as if key left in but already out - tried disconnecting then reconnecting battery for a few minutes but still nothing works.
Try a BSI reset:-
Here are the steps (These are followed and if disconnecting the battery for more than 5 minutes).
1. Put the driver's window down, lift the bonnet and ensure all equipment is switched off.
2. Ensure all doors are closed and remove key from the ignition.
3. Wait for 3 minutes, disconnect the vehicle battery and wait 15 seconds.
4. Reconnect the vehicle battery, wait a further 10 seconds (do not open doors.).
5. Switch on the side lights through the driver's window.
6. Switch on the ignition and check system's functionality.
7. Hold lock button on key down for 10 seconds.
8. Remove key open & close door test central locking system.
9. Start the engine and complete the system's check.
Failure to follow this procedure could result in incorrect operation of many BSI related items
If this doesn't work, some others will be along to help before too long, in the meantime, whilst you are waiting, have a look here:-
http://www.berlingoforum.co.uk/showthread.php?tid=815 :wave:
  • ewenfnr
With all electrics dead I can't do first step, can I?
(15-04-2012, 03:16 PM)ewenfnr Wrote:  All electrics totally dead - worked fine yesterday until got home when started beeping as if key left in but already out - tried disconnecting then reconnecting battery for a few minutes but still nothing works.
The other day the good wife came to me in a panic , its beeping at me and I think theres something wrong,!
Switch off the sidelights, dear
Oh OK thats cured it
Confusedillyme:
(15-04-2012, 06:40 PM)ewenfnr Wrote:  With all electrics dead I can't do first step, can I?
Try doing step one by leaving the door open instead, and then get someone else to hold in the door light switch so that the car thinks the door is shut also I am only presuming you have a switch
Have you tried testing/charging your battery?
[-] The following 1 user says Thank You to knobblywobbly for this post:
  • ewenfnr
Can you not just get someone to sit in the car?
Good point
Also check main fuses
[-] The following 1 user says Thank You to ifred for this post:
  • ewenfnr
First check the voltage at the battery. Less than 10volts and it's probably a dead 'un. Should read a bit over 12v.
Then check both ends of the battery leads for corroded or loose connections. Remove and clean if necessary.
When you've checked all of those things and it's AOK then start
looking for more complex problems. HTH:thumbsup:
[-] The following 2 users say Thank You to Ol'Jeffers for this post:
  • ewenfnr, Rustscrat
Confusedillyme:
Classic ! :lol:
Back pain / ache
Last Post: jw4821
Today 06:23 PM
Indicator/lights Stalk
Today 04:55 PM
2011 B9 DPF warning light
Last Post: IKUN
Today 04:51 PM
Yesterday 04:48 PM
Last Post: BrianS
Yesterday 01:58 PM
» Replies: 24
Drop in fuel economy
Last Post: Andhall
Yesterday 09:21 AM
Not able to register
Last Post: Mike
22-01-2025 11:03 PM
Last Post: Matt Haigh
22-01-2025 07:21 PM
M59 rear wheel splay...
21-01-2025 03:27 PM
Last Post: pondweed
21-01-2025 01:21 PM
