Threads: 6
Thanks Received: 8 in 7 posts
Thanks Given: 9
Hi all, I have picked up my new berlingo today, and on attempting to swap the standard headunti for my own kenwood bluetooth one I have found a problem. When I turn the ignition off the stereo stays on, even after the dash display shuts off the stereo is still playing away!
Any ideas why or how to sort this out?
Cheers Rob
Threads: 32
Thanks Given: 24
For how long does it stay on?
Threads: 6
Thanks Given: 9
At least 5 minutes, haven't sat for too long waiting for it to turn off but obiously need it to go off when getting out and leaving the car.
Threads: 6
Thanks Given: 9
After lots of reading old posts and a bit of trial and error got the memory working. It's still taking the switched live from the eco live but does shut off after a couple of minutes, will have to remember to take the face off when leaving the car now.
Cheers all.
Threads: 32
Thanks Given: 13
18-04-2012, 10:24 PM
(This post was last modified: 18-04-2012, 10:27 PM by tucker.)
Mine did that. There is a switched live feed on the iso connector.
I had to pull the proper switch live out and put it where the eco live was.
I think somewhere I posted a reference to which number feed on the iso connector was the proper switched live. On mine, it was wrongly made redundant and the eco live was used, so it needed moving to get it spot on.
I will see if I can find what I did. Otherwise it actually comes live when you open the doors!! If you leave the face on and let it turn off. Get out of the car and leave it, when you return and open the door the head unit kicks in and starts playing!!
