  • 31 Vote(s) - 2.52 Average
[How To] Remove-Refit rear bumper on M59 (Mk2)
1. Removing
Disconnect the battery .
Remove :
The tail lights
The rear mud shields
[Image: rrbp1.png]
Remove :
The screws (3) and (4) (in the wheel arch) (on each side)
The screws (1) and (5)
The bolts (2)
Release the clips (6).
Remove : The external bumper skin (7).
[Image: rrbp2.png]
Remove :
The bolts (8)
The bumper absorber (9)
2. Refitting
2.1. Recovered bumper support
Proceed in the reverse order to removal.
Tighten the screws (1), (2), (3), (4), (5), (6), (8) to 0,8 m.daN .
Connect the battery.
Check all the equipment works.
2.2. New bumper support
[Image: rrbp3.png]
A : Previous assembly.
B : New assembly.
ATTENTION : When replacing an old bumper, the fixings ( 11), (12) must be ordered.
Only the later parts will be available from Parts Div..
Remove the retaining clip ( 10) fixed inside the rear wing (on each side).
Fit :
The cage nut (11) on the rear wing (on each side)
The rear bumper
The (12) bolt (on each side)
many thanks pk7478
Hi please can you kindly send a link for the image. Kind regards Julie
I think you may be out of luck, the thread is 6 years old.
You may be better off starting a new thread with your queries/problems.
Malcolm
2001 1.9D Multispace.
It's a shame that the pictures disappear form tutorial threads as the pictures are key to the thread.
I've came across hundreds of threads on forums over the years that are rendered useless because the pictures are missing.
I realise that the pictured are often deleted by the hosting site but is there not a way that the pictures can be made a permanent fixture to the thread, maybe by adding the picture as an attachment?
It would make tutorial threads like this one future proof.
Emissions fault.
11-05-2025 06:29 AM
10-05-2025 05:31 PM
Winter Tyres
10-05-2025 02:42 PM
Start stop on van
Last Post: Rhino2k
09-05-2025 10:28 PM
09-05-2025 09:34 PM
Insurance Shocker !!!
Last Post: Keefus.
09-05-2025 01:45 PM
Part of Dipstick Stuck
Last Post: Nice4dad
09-05-2025 01:25 PM
BSI central locking again
Last Post: stuffe
09-05-2025 09:24 AM
» Replies: 23
steering column bearings
07-05-2025 07:53 PM
Gen 1 cream interior cleaning
07-05-2025 06:28 AM
