  • 12 Vote(s) - 2.5 Average
Rattling Rear Door
Hi, getting a intermittent rattle from rear door / rear window area- cannot seem to locate exact spot. Anyone suffered from this ? If so, how best to fix it ? Thanks.
Have you checked the lock sometimes comes loose and gives a rattle;0)
[-] The following 1 user says Thank You to blingo driver for this post:
  • taxi
As blingo said. Check the locks. My boot lock plate bolts loosened and the boot used to rattle over bumps etc.
Sent from my GT-I9000 using Tapatalk 2
1.9d Mk2 (M59/BE4/5) with battle scars from a conservatory attack. Previously owned a 1.4i Mk2 Forte.Confusedalut:
[-] The following 1 user says Thank You to divingscubaboy for this post:
  • taxi
It now seems more likely to be coming from the top rear corner ( passenger side ) possibly eminating from behind the aperture which the central seat belt appears out of.
(24-04-2012, 08:13 PM)taxi Wrote:  It now seems more likely to be coming from the top rear corner ( passenger side ) possibly eminating from behind the aperture which the central seat belt appears out of.
Hi,
I think I had the same problem,
only after I had let a friend of mine drive my car and sat at the back sit
I found out that my noise was coming from a plastic unit the is located on the beam between the front and back door.
if you open the door there is a pin closer to the top of the door that will go to the plastic part on the beam.
It took me while to find it.
Smile
Let me know if this is it.
[-] The following 1 user says Thank You to Gal for this post:
  • taxi
We had a rattle early on - it was the catch on the sliding door window, the nut wasn't quite tight enough.
The Bus II: 2019 XL Flair 1.2
[-] The following 1 user says Thank You to Guanajuato for this post:
  • taxi
(19-04-2012, 10:49 PM)divingscubaboy Wrote:  As blingo said. Check the locks. My boot lock plate bolts loosened and the boot used to rattle over bumps etc.
Happened to me too, I had to buy a cheap socket-set just to get a small range of the weirdo (torx?) doodads just to tighten things up Smile
Sorry for the late replay.
This is a picture of the part that was doing
[Image: 14o7ii9.jpg].
[-] The following 2 users say Thank You to Gal for this post:
  • CandR, taxi
eolys
Last Post: magoo1
Yesterday 03:02 PM
Rattling calipers
18-05-2026 05:36 PM
Yet another ABS fault
13-05-2026 05:57 PM
Mileage
Last Post: Taffy747
11-05-2026 11:51 AM
11-05-2026 09:17 AM
03-05-2026 01:27 PM
Head unit quad lock
03-05-2026 11:17 AM
Spare Key Fob?
29-04-2026 08:05 PM
29-04-2026 06:27 PM
Eolys problem
24-04-2026 07:07 PM
