  • 13 Vote(s) - 2.62 Average
[Engine] Fuel tank half full, revving highly on its own.
Hi.
I have 98 1.9diesel berlingo (800), with 110000 miles, i seem to be having a problem when the diesel tank reaches half empty the engine acts strange the revs jump very high on their own also there is a lot of blue smoke till finally the van stalls like it ran out of diesel. I would aprriciate any help on fixing this problem as it is very frustrating.
Yours kindly,
Frustrated Berlingo driver.:brickwall:
Mines the same when it hits quarter of a tank
[-] The following 1 user says Thank You to muply for this post:
  • Berlingo
Sounds like it's running on its own oil to be honest, has it always done it or is it a new feature?
[-] The following 1 user says Thank You to northants_guy for this post:
  • Berlingo
(24-04-2012, 07:28 AM)northants_guy Wrote:  Sounds like it's running on its own oil to be honest, has it always done it or is it a new feature?
Used to happen a lot years ago with diesel engines. Eventually they fix themselves, they rev and rev until all remaining oil is drawn from the sump and the engine then seizes up...
  • Berlingo
Nope its no a oil issue more of a air in pipes issue happens to mine when im low on juice its as if a ping pong ball is in the tank and when it gets low it cover the outlet hole
  • Berlingo
(24-04-2012, 03:27 PM)muply Wrote:  Nope its no a oil issue more of a air in pipes issue happens to mine when im low on juice its as if a ping pong ball is in the tank and when it gets low it cover the outlet hole
Thats exactly how mine acts taught my fuel gauge was broken was wondering is there any way of fixing this
Could this be a blocked fuel tank vent? which would cause a vacuum in the tank.
[-] The following 1 user says Thank You to Trevor for this post:
  • Berlingo
Im unsure at the mo its hard to trace ive just started running mine with the fuel cap off to see if that makes any difference will let you no
(25-04-2012, 03:15 AM)muply Wrote:  Im unsure at the mo its hard to trace ive just started running mine with the fuel cap off to see if that makes any difference will let you no
I would not run with the cap off, just open then replace it at the end of each day.
Didnt work anyhow lol
Yesterday 09:14 PM
Yesterday 03:21 PM
Last Post: JPCoetzee
12-03-2026 03:52 PM
OIL Drip
12-03-2026 01:49 PM
10-03-2026 10:47 PM
10-03-2026 09:14 PM
10-03-2026 02:49 PM
New owner in Bristol UK
10-03-2026 01:19 PM
Last Post: Alberts elbow
09-03-2026 10:11 PM
09-03-2026 05:17 PM
