  • 13 Vote(s) - 3.23 Average
Glow Plug change
Please can someone advise me on how difficult it is to change the glow plugs on my 54 berlingo. I know very little about cars, but i have been shown where they are located. Do i need a special tool to get them out and do i have to take off all the plastic housing above themConfusedcratch: Cheers Guys!!
very easy to change 1 hour job
[-] The following 1 user says Thank You to muply for this post:
  • Rob the Buff
(25-04-2012, 03:11 AM)muply Wrote:  very easy to change 1 hour job
Do i need a special socket? And do i need to take off the plastic air thing on top:justno:
I have attempted to take off the plastic hose cover??? but could not shift it, any ideas how to move it, pl,pl,pl,pl,please help!!
you need to remove the inlet manifold it black then you require a socket to remove wire from glow plug and the a socket to remove plugs
  • Rob the Buff
I undone 2 visible screws on the inlet thing, but could not get it to move. I was afraid i would break something!! Does it need to be a deep socket,as i only have what i would describe as a normal socket set.
yep would say deep but only small sockets should be a easy job have you checked glowplug relay located by passengers side headlight black box
  • Rob the Buff
Are they like the "Glow-Plugs" in model aircraft ????
yep quite small
(25-04-2012, 03:45 PM)muply Wrote:  yep would say deep but only small sockets should be a easy job have you checked glowplug relay located by passengers side headlight black box
No i have not checked the relay , dont know what it looks like, or even what to do if i found itWink I noticed there is like a pump thing near the air in take thing?? I have bought NGK glow plugs, they are about the size of a spark plug
To be honest given what appears to be very limited mechanical knowledge I'd stay well away from the engine !
Any advice regarding boot carpets being wet!?
Today 05:41 PM
2011 B9 DPF warning light
Today 02:22 PM
Today 10:53 AM
Frequent DPF REGEN's
Yesterday 08:43 PM
Power Steering gone - reservoir full, hoses and ...
Last Post: Collapsedsuspension
Yesterday 02:29 PM
Power flex anti roll bar bushes
Last Post: NANO_Vigo
Yesterday 10:54 AM
Power flex lower wishbone bushes
Last Post: AD246
Yesterday 08:54 AM
How to change your username
Last Post: Mike
16-01-2025 11:04 PM
Spot the Berlingo(s)
16-01-2025 12:20 AM
knocking from rear
15-01-2025 04:59 PM
