Top clock screen upgrade.
Hi everyone, is there any way to upgrade the top screen with the time of the berlingo? I have the simplest one with only the time, and im interested to ipgrading it to the large one with the time and outside temperature. If its possible, has anyone done it to be able to tell me what everything I need?
TIA Smile
I changed one over on a B9, it is a straight swop. unplug old one and plug in the new one..
It depends if you have the outside temperature sensor in the mirror head, don't know if the M49 has it.
2020 Rifter 1.5 allure
2010 B9 red XTR w a v.
2005 2.l green Berlingo
berlingo 1.4 red multispace
1993 xud 1.9 red partner
(28-11-2023, 11:16 AM)brodfather11 Wrote:  I changed one over on a B9, it is a straight swop. unplug old one and plug in the new one..
Since it never shows, even through OBD2 scanner in sensors for outside temp, I dont think it has it. Ill try to figure it out if its possible to add it or not.
Try a search there is loads of info on this topic.
Search for multi fuction display or mfd or outside temperature
I tried a quick search https://www.berlingoforum.com/search.php...order=desc
edit ^^^^ I did it a few years back on my M59 ... quick and easy
I'll look for a post about it
Have a read here .. https://www.berlingoforum.com/thread-799...ht=display
There is more stuff to look at so have a search
(02-12-2023, 07:23 PM)geoff Wrote:  Have a read here .. https://www.berlingoforum.com/thread-799...ht=display
Thank you very much for pointing me towards the right direction. Ill check what i can find in the forums. Smile
(02-12-2023, 07:21 PM)geoff Wrote:  edit ^^^^  I did it a few years back on my M59 ... quick and easy
Was it basically plug and play? Or was it more difficult. I have the most basic one where i only have the time and the two buttons on the side to change the time.
Simply plug and play ... hardest part is removing the trim ( easy )
Today 03:10 PM
Yesterday 05:28 PM
Last Post: kulat
03-09-2026 09:59 PM
31-08-2026 08:50 PM
29-08-2026 08:39 PM
29-08-2026 08:26 PM
29-08-2026 05:45 PM
24-08-2026 07:58 PM
23-08-2026 06:25 AM
Last Post: stu76
18-08-2026 07:16 PM
