Berlingo reverse light cable.
Hi, i'm tryint to find out which wire is the reverse wire in the berlingo. I know they arent color coded, but Idk how to figure out which is the reverse 12v and ground. Im trying to connect a reverse camera to it.
Thanks for any insights on the matter [Image: icon_smile.gif]
How about switching on the ignition , putting it into reverse gear , then with a test lamp or meter find the wire that's live at the rear of the tail lamp ?
The wires also have numbers on them , it maybe 220 for early berlingo or 2200/2210 for later.
Be careful , the BSI can be damaged if shorted out
2020 Rifter 1.5 allure
2010 B9 red XTR w a v.
2005 2.l green Berlingo
berlingo 1.4 red multispace
1993 xud 1.9 red partner
Yesterday 05:21 PM
Yesterday 05:12 PM
04-11-2026 11:37 PM
Last Post: Drantanborg
31-10-2026 03:59 PM
24-10-2026 08:09 PM
