Wire to tap into for DRL install
Hi
I have a 2004 2.0 HDI berlingo M59.
I want to install DRL (Daytime Running Lights) somewhere in the bumper. I was wondering what's the easiest wire under the bonnet to tap into for the "+"
It would be great if it was a wire that only sends power if the engine is running. If that's complicated or tough to tap into, i will settle for + on ignition.
Thank you all
Bumping this up, hopefully for an update. Thanks
The easiest would be the engine fuse box. There will be a "ignition on " fuse that you could piggyback a feed to operate a relay to supply your DRLs.
There will be a permanent feed in there also for the always live for the other side of the relay
2020 Rifter 1.5 allure
2010 B9 red XTR w a v.
2005 2.l green Berlingo
berlingo 1.4 red multispace
1993 xud 1.9 red partner
  • Sahloul
(11-03-2024, 09:01 AM)brodfather11 Wrote:  The easiest would be the engine fuse box. There will be a "ignition on " fuse that you could piggyback a feed to operate  a relay to supply your DRLs.
First off:
Thank you so much for your response. Do I have to put a relay? Is it dangerous if i just plug them in directly? (They are a couple of led strips that don't draw much power)
Second: i would rather not fiddle with the fuse box, as running  a wire there seems a bit "botched". How about the glow plugs heater box behind the headlight? You think i can tap into that? I figured it would have a + switched in there.
Try it and see , if it works good , if it doesn't then think again
If the glow plugs come on they are only on for max 3mins .
The feed that works the relay may do what you want
Coolant
Last Post: Martinze
Yesterday 08:24 PM
Leaking windscreen or aerial
15-04-2026 08:50 PM
