FUI: K9 tweeter
Those sneaky little French men.
The tweeter is installed but the connector is not connected
Attached Files Thumbnail(s)
I'll ask.....
What's a tweeter?
Now a 2019 K9 1.2 petrol.
High frequency loudspeaker.
ex: 2003 1.4i cargo
I checked 3 berlingos today. and all of them had a tweeter, but the cable was connected to a dummy plug. Arfter moving the connector, the owners was happy Smile
(07-12-2023, 03:55 PM)Tikki Wrote:  I checked 3 berlingos today. and all of them had a tweeter, but the cable was connected to a dummy plug.  Arfter moving the connector, the owners was happy Smile
How hard is it to get to these ?
2022 LWB 1.2 petrol auto combo life (AKA Berlingo K9)
Learn something new everyday.....
They are pioneer tweeters, and i think they are in all K9's, but the cable is just not connected to the speaker.
take a thin object between the cover and the window devider and pull it away from the window. the plastic cover is hold on by one clip, and just wiggel it of the door cover.
Can you show some photos of this Tikki.?
Thought I'd better look at mine.On the driver's side the wiring was correctly connected to the tweeter but on the passenger side the tweeter was not connected and there was no sign of the wiring or the plug. I used my USB endoscope to peer down inside the door card and found the missing plug and was able to retrieve it with a bent coat hanger. Now connected and the radio sounds much better.
A tip for any member looking to remove interior trim fittings; have a look for the part on ebay. The seller will usually post several photos of the part and hopefully show the reverse side and the retaining clips. You can then see which way to push or pull to remove the item
[-] The following 1 user says Thank You to Cumbrian for this post:
  • Matt Haigh
Last Post: Desdinova
08-09-2026 05:46 PM
07-09-2026 09:06 AM
Last Post: BDRichardson
06-09-2026 04:07 PM
Last Post: kulat
03-09-2026 09:59 PM
31-08-2026 08:50 PM
29-08-2026 08:39 PM
29-08-2026 08:26 PM
29-08-2026 05:45 PM
24-08-2026 07:58 PM
23-08-2026 06:25 AM
