Which Lexia please
Hi All
Wonder if somebody could point me to the best (eBay) Lexia I need to purchase for my 2014 Berlingo Van please. Need to get to the bottom of my, “fan staying on” & (ABS) issues.
Thanks in advance
Maybe look into this, as it might be a cheaper alternative?
https://www.berlingoforum.com/thread-27737.html
_______________
Not a Citroen  Cry
2008 B9 1.6Hdi Multispace XTR
2002 Xsara Picasso 2.0Hdi
1996 ZX 1.9TD Estate
(10-12-2023, 01:47 PM)Multispacer Wrote:  Maybe look into this, as it might be a cheaper alternative?
Thanks buddy,
I already have a  TopDon scanner & wurth snooper, and ideally want the specific Citroen software as I want to add cruise control etc in the future
The magic words on eBay are "full chip lexia", which will bring up a selection of sellers.
Top Tip - don't bother trying to install the software directly onto a laptop, it's a PITA. Either choose a seller that provides it already installed in a virtual machine, or use the VM images that are floating around on here. Much, much easier. There's threads around here on that, but it's not complicated. Install VMware Workstation, add the VM image, say "I moved it" when starting, and map the USB device through to the VM.
I increased the CPU count and RAM to 4 and 4GB from the seller's original, and it seems to work nicer than the defaults it was supplied with (2 and 2GB).
Do bear in mind the Chinese knockoffs have some limitations - anything requiring the tool talk back to Citroen is out, so coding with later versions of software won't work. Again, plenty reading on other threads.
Last Post: BrianS
Today 12:56 PM
» Replies: 22
Pling sound when door open
Last Post: Mark604
Yesterday 07:52 PM
Hello
Last Post: Pricklybuzzz
Yesterday 07:08 PM
Fuel Gauge trouble
Yesterday 10:44 AM
2011 B9 DPF warning light
18-01-2025 11:52 PM
Any advice regarding boot carpets being wet!?
18-01-2025 05:50 PM
» Replies: 21
18-01-2025 10:53 AM
Frequent DPF REGEN's
17-01-2025 08:43 PM
Power Steering gone - reservoir full, hoses and ...
Last Post: Collapsedsuspension
17-01-2025 02:29 PM
Power flex anti roll bar bushes
Last Post: NANO_Vigo
17-01-2025 10:54 AM
