M59 Speedo sensor location
2006 1.9d van
Hi, Folks, just spent half a morning under my van looking for the speedo sensor...I have the replacement, but can't find where it goes.  Huh
Does any one have a clear location diagram please?
I have found a blanking plug with a 3 pin plug attached....is there a version that gets the speedo signal some place else?
Also found a sensor held by an allen bolt at the top of the bellhousing, close to the engine and another sensor at the front of the gearbox with a 2 pin plug, neither of which look at all like the new sensor delivered.
TIA
Different vehicle, but looks like the same sensor, in more or less the same location, just above the passenger side driveshaft.
https://www.youtube.com/watch?v=2pRilRhtR8I
Drivers Side  Rolleyes
(18-12-2023, 09:00 PM)RJBingham Wrote:  Different vehicle, but looks like the same sensor, in more or less the same location, just above the passenger side driveshaft.
Got the van up on the ramp again, there is nothing above the r/h driveshaft where indicated on the video. I am increasingly convinced that it has a different sensor type/location to the one I have purchased.
What other options are there, anyone??
Further update....
Looked at two other 1.9d engined vans today, both had the speedo sensor in the position mentioned above. My van has a clearly visible blanking plug there instead.
Can any one please point me to an alternative speedo pick up on these vehicles?
why not try the replacement you have to see if it fits blanked off hole and works ?
2020 Rifter 1.5 allure
2010 B9 red XTR w a v.
2005 2.l green Berlingo
berlingo 1.4 red multispace
1993 xud 1.9 red partner
Has the van got ABS? ..... Just thinking the speedo signal may come from that.
Thanks Brodfather, but I don't have the cog to enable me to fit the sensor I have.
Ah, yes, JJ9, it is an ABS model...that would make sense.
Will investigate. Thanks.
(14-01-2024, 12:11 PM)BingoB Wrote:  Thanks Brodfather, but I don't have the cog to enable me to fit the sensor I have.
ABS model have wheel sensors. That's why you can't find it.  Smile
Pling sound when door open
Last Post: Mark604
Today 07:52 PM
Hello
Last Post: Pricklybuzzz
Today 07:08 PM
Fuel Gauge trouble
Today 10:44 AM
2011 B9 DPF warning light
Yesterday 11:52 PM
Any advice regarding boot carpets being wet!?
Yesterday 05:50 PM
» Replies: 21
Yesterday 10:53 AM
Frequent DPF REGEN's
17-01-2025 08:43 PM
Power Steering gone - reservoir full, hoses and ...
Last Post: Collapsedsuspension
17-01-2025 02:29 PM
Power flex anti roll bar bushes
Last Post: NANO_Vigo
17-01-2025 10:54 AM
Power flex lower wishbone bushes
Last Post: AD246
17-01-2025 08:54 AM
