6 speed gearbox
On the motorway, my 2014 B9 Multispace XTR always seems to crave a 6th gear. Has anyone carried out a 6 forward speed gearbox change and been successful with it....?
It's the sort of thing that is probably not feasible financially, there's a lot fo stuff to change or modify.
Definitely,
Gearbox
Driveshafts
Engine\box mounts
Probably,
Flywheel,
Clutch
Starter
Clutch hydraulics
Maybe,
Adaption\machining of input shaft\crankshaft. Depends if the input shaft\crank arrangement is the same.
Gear selector
Gear sensor\coding
By the time you've done all that (and it's a PITA to take the gearbox out on these), you've probably spent more than just buying one with the 6th gear already there.
[-] The following 1 user says Thank You to shtu for this post:
  • BER-LINGO
As well as all of the above, do you know, for a fact, that sixth gear on the six speed box is actually a higher gear than fifth gear on the five speed box?
Geoff
[-] The following 1 user says Thank You to Guanock for this post:
  • BER-LINGO
Removing sticker residue
Last Post: BikerGran
Yesterday 09:19 PM
Where Did you find Berlingoforum.com?
Yesterday 09:13 PM
» Replies: 105
Gearstick hitting the exhaust pipe
Last Post: felipecoswig
Yesterday 09:07 PM
Just joined
Yesterday 08:38 PM
Which Oil?
Last Post: Climber
Yesterday 08:31 PM
Camper Conversion
Last Post: Stockygraham
Yesterday 07:57 PM
What does a service consist of ?
Yesterday 06:14 PM
So long and thank's for all the fish!
Yesterday 05:35 PM
Replacement van door check strap(?)
Yesterday 05:31 PM
newbie here
Yesterday 04:18 PM
