Rear spring upgrade
Hi all,
I have a 2018 75hp 625 enterprise, I carry a bit of weight in the back but nothing excessive however the rear of my van looks fairly low compared to the front, is there any stiffer rear springs or upgraded ones that could raise it up a little?
Don’t really want coilovers
The van is on 140k so could be a little tired any suggestions would be grateful
Tanks Paul
There's not much in the way of options but this thread might help
https://www.berlingoforum.com/thread-26228.html
_______________
Not a Citroen  Cry
2008 B9 1.6Hdi Multispace XTR
2002 Xsara Picasso 2.0Hdi
1996 ZX 1.9TD Estate
I was going to suggest the Mutispace xtr ones, it has a higher ride height than other models.
Might have to do some trawling of catalogues to get rates\lengths, you might find the van types are higher rate but shorter length.
As you say, could even be that new standard ones are all that's needed, but can't say either way from here.
So I’ve been having a look on eBay ext and found some heavy duty springs that are 410mm however the listing says they won’t fit my van.
I’m pretty sure they would be the same as my originals just longer, but can anyone confirm that they will fit?
Would these help?   https://towsure.com/products/towing-spri...e5ce&_ss=r
Attached Files Thumbnail(s)
(01-01-2024, 12:37 PM)Cumbrian Wrote:  Would these help?   https://towsure.com/products/towing-spri...e5ce&_ss=r
Never seen these before but will look into them, thanks
They are obviously intended for towing but I have seen them used front and rear as a cheap and simple way of stiffening up a car's suspension.
Yeah I’ve ready that, I carry tools in the back that I don’t really want to take out along with a tool vault and even tho I didn’t think it’s too much weight it’s basically on the bump stops and looks like it’s draggin, so just want the back abit higher.
Hi
Mad spring the best for havy load.
https://mad-suspension.co.uk/product/hv-133248/
Regards
Vigo, The cradle of all Berlingos / Partners.  Big Grin Heart
I've got about 400 kilos of tools and equipment in my little service van (B9 L1 675kg), so she was a bit saggy at the back (and felt awful to drive, not exactly confidence inspiring), so I installed some "heavy duty" springs from ebay (bnib, "Kilen" branded"), and those brought the ride-height back up to what it should be, and eliminated it's previously wayward nature!
They were pretty easy to fit, but you'll need a decent set of spring compressors, and they need to be fairly compact. I used the type that has 2 stout hook things on a piece of counter-threaded bar. The bump-stops were a bugger to get off the spring, and were a bit knackered anyway, so do yourself a favour and just get new ones before you start! and use plenty of lube to fit them!
I did try the rubber-spring helpers as a short-term measure, but they didn't really do much. don't bother unless you're desperate (and don't expect miracles if you do!)
Thanks to the above posters, you helped me solve my problem!
Berlingo digital cluster speedometer upgrade
Last Post: kaktusas
Yesterday 02:48 PM
Cruise control retrofit
14-12-2025 09:37 PM
14-12-2025 01:33 PM
14-12-2025 12:49 PM
14-12-2025 12:00 PM
Anti Pollution fault warning
14-12-2025 11:39 AM
An almost Hydrolock in a DV6B
Last Post: chrisl
14-12-2025 09:36 AM
Last Post: chrisl
14-12-2025 09:27 AM
tyre pressure monitoring system (TPMS)
10-12-2025 07:50 AM
Wishbone Lower Control Arms Questions
09-12-2025 07:19 PM
