Threads: 43
Thanks Received: 416 in 373 posts
Thanks Given: 139
33
The number 1 pressure values seem high at 115 % ( ??? ) Could be a sticky injector.
Possibly a bottle of diesel injector cleaner will help .
2020 Rifter 1.5 allure
2010 B9 red XTR w a v.
2001 1.9d DW8B white Berlingo
2005 2.l green Berlingo
berlingo 1.4 red multispace
1993 xud 1.9 red partner
Threads: 43
Thanks Given: 139
33
01-01-2024, 04:08 PM
(This post was last modified: 01-01-2024, 04:09 PM by brodfather11.)
One way of checking blocked injector pipe was to touch it and if it is hotter than the rest its a sign of a blockage either in the pipe or injector,
When i had a 2.0 ltr I used redex every fill up put in the tank.
I assume the % means its 115.% of the max pressure 259 bar .
Why is it in French .Isn't there a way of changing language unless you are French ?
Edit Sorry did'nt notice you are from Tunisia
Threads: 10
Thanks Received: 27 in 26 posts
Thanks Given: 6
(01-01-2024, 02:23 PM)Sahloul Wrote: (01-01-2024, 09:04 AM)brodfather11 Wrote: The number 1 pressure values seem high at 115 % ( ??? ) Could be a sticky injector.
Hi
Thank you for your response!
Should i just add the cleaner to the fuel tank or what?
I normally pre-fill a new fuel filter with Forte Injector Cleaner. It's one of those things that everyone's got an opinion in, but that's what works for me.
If you're not sure about the numbers the diagnostic system is giving you, you can do a leak-off test. No need for fancy kit, just some pipe and 4 coke bottles works. Run the return pipes from the injectors into a bottle each and see which one/s fill up fastest, they'll be the faulty ones.
Could be worse.... Could be a Caddy.
