06-01-2024, 12:32 PM
Hi
I have an 07 HDI 90 Peugot MPV with 140k on the clock.
Following advice I tried running it at high revs for a few miles the other day at the end of a long trip, as it often just gets short journeys. After that it ran well when over 2000 RPM but is lumpy / uneven when at low revs. After a couple of weeks it started running normally, and well.
Later I tried the high rev routine again and it was followed by the same problem of uneven running.
I have looked around the forum expecting to find this is a known problem and perhaps even something I can do to get the car back to smooth running quickly. So far I've not found anything hence posting this and hoping to get some learning and advice.
OK so I won't bother trying the high revs routine again and am hoping that it will return to good running in time.
