OEM Towbar wiring installation manual
I've managed to cobble together the OEM fuse box and wiring loom to the external socket from various sources.
Car has the preprep wiring (front to back) for the towbar.
I've put the maxi fuse for the white wire (12v confirmed).
It would be helpful if anyone had a scan of the original installation instructions to a) make sure I've got the right plugs in the right holes (the two power connectors look very similar and appear to be interchangeable) and b) how to mount the fusebox (there's no obvious mounting points for it).
I've got Lexia to do the coding for when it's all installed correctly.
Links I've found so far on the forum have expired.
Looks like the manuals from any of these will do:
7 pin - part number 1606489280
7+7 pin - part number 1607814280
13 pin - part number 1607814080
Hi
Here I atached the manual for the Berlingo B9. Is not the original.
Maybe will help you.
https://www.rameder.eu/out/media/182291-...les-v2.pdf
Vigo, The cradle of all Berlingos / Partners.  Big Grin Heart
Thanks for the manual.
Unfortunately I’m looking for the OEM one as it’s the position and connections of the manufacturer trailer fuse box I’m looking for.
2011 B9 DPF warning light
Last Post: IKUN
Yesterday 09:44 PM
Frequent DPF REGEN's
Yesterday 08:43 PM
Power Steering gone - reservoir full, hoses and ...
Last Post: Collapsedsuspension
Yesterday 02:29 PM
Last Post: paulod
Yesterday 12:05 PM
Power flex anti roll bar bushes
Last Post: NANO_Vigo
Yesterday 10:54 AM
Power flex lower wishbone bushes
Last Post: AD246
Yesterday 08:54 AM
How to change your username
Last Post: Mike
16-01-2025 11:04 PM
Spot the Berlingo(s)
16-01-2025 12:20 AM
knocking from rear
15-01-2025 04:59 PM
Last Post: Andhall
15-01-2025 04:59 PM
