Threads: 7
Thanks Received: 1 in 1 posts
Thanks Given: 2
hello all, I have a faulty rear parking sensor to replace and was wondering how easy it is to remove the bumper trim as i cant access the sensor without doing so. Incidentaly luckily i know which one it is as the main dealer diagnosed it whilst in for another job however i dont have the part number which is another question...does anyone know the part number ???
Many thanks
2015 XTR 120bhp blu eco
Threads: 7
Thanks Given: 2
That's brilliant many thanks, most helpful. ?
Threads: 6
I replaced all 4 sensors in mine - system wasn't working and they're cheap enough so didn't both to track down the faulty one and just replaced all 4. Didn't need to remove the bumper either but it's tight underneath as you say.
The system and sensors work fine but the fault code is still stored in the parking module. So every time I engage reverse I get the error beep and then it springs into life.
The following 1 user says Thank You to jw4821 for this post:1 user says Thank You to jw4821 for this post
• ips
Threads: 7
Thanks Given: 2
Did you replace with aftermarket or oem
Threads: 6
Aftermarket ones. Check the connector as there’s different types.
