Berlingo 2007 1.6 hdi - intermittent sticky accelerator pedal
Morning all
I had an issue with the van yesterday. The heater was on full (into the footwell) and we were stuck in traffic for a quite a while. The accelerator started to stick and not return, resulting in very high revs, that took a few secs to return to normal idle. I was able to put my foot underneath the pedal, to push it back up, which got me home. I went back to to the van afterwards (about half an hour) to see if I could find out what it was, but the pedal was no longer sticking and seemed fine. Could it have been something to do with the constant heat going onto the pedal from the blower ? If so, I assume I could add some lubricant to the pivot ??
thanks
Dave
Just read a couple of threads from other members, and it looks like it's not an uncommon problem. I will follow the advice given on the other threads..
regards
Dave
It is a simple and quick job to remove the pedal assembly.
Liquid lube is then easily applied.
Dismantling further looks problematic and probably best left alone though new assemblies are readily available if it all goes tits up.
Any chance someone can put a link to the other threads about the accelerator pedal please
Peter
(19-01-2024, 10:12 AM)Romahomepete Wrote:  Any chance someone can put a link to the other threads about the accelerator pedal please
Peter
https://www.berlingoforum.com/thread-221...ator+pedal
_______________
Not a Citroen  Cry
2008 B9 1.6Hdi Multispace XTR
2002 Xsara Picasso 2.0Hdi
1996 ZX 1.9TD Estate
I thought that I had fixed my sticky accelerator pedal but it has returned. It is a 2007 M59 1.6 diesel. Does anyone know if the pedal from any other citroen or peugeot can be sued instead. There seem to be plenty of B9 pedals on Ebay
Peter
(10-03-2024, 01:35 PM)Romahomepete Wrote:  I thought that I had fixed my sticky accelerator pedal but it has returned.  It is a 2007 M59 1.6 diesel.  Does anyone know if the pedal from any other citroen or peugeot can be sued instead.  There seem to be plenty of B9 pedals on Ebay
Peter
I've been wondering the same, mines gone again, close matches but no direct on Ebay.
I took mine apart and lubricated the pivot but it was only a temporary cure. I have fixed it though with a new pedal from Citroen at £202 plus VAT.
Peter
(28-03-2024, 01:05 PM)Romahomepete Wrote:  I took mine apart and lubricated the pivot but it was only a temporary cure.  I have fixed it though with a new pedal from Citroen at £202 plus VAT.
Peter
Ouch, gone up a bit too from when I last enquired a few years ago!
May have to go the same route.
(18-01-2024, 03:48 PM)geoff Wrote:  It is a simple and quick job to remove the pedal assembly.
Hi Geoff,
many thanks for the information and apologies for the delay in getting back to you.   Smile
[-] The following 1 user says Thank You to Dwight07 for this post:
  • geoff
wipers
Last Post: mickrochip
Today 11:26 AM
Last Post: xavier988
Today 10:23 AM
Today 10:21 AM
knocking from rear
Today 10:19 AM
footwell fan
Last Post: de62
Yesterday 10:13 PM
rear washer fires front?
Last Post: Brooky325
Yesterday 10:00 PM
Remote key fob window function?
Yesterday 05:58 PM
Halp, me van had died :(
Last Post: ae3
Yesterday 05:43 PM
Drop in fuel economy
Yesterday 09:38 AM
Berlingo in disguise..
Last Post: BlackPartner
11-01-2025 09:47 AM
» Replies: 34
