Threads: 28
Thanks Received: 19 in 18 posts
Thanks Given: 4
12
I'm certain that my service interval notification has been on the same mileage all day, despite actually covering 100 miles or more. The covered distance is racking up as it should. Though I think that the service had dropped 100 miles after being parked last night after a period that I didn't think it had dropped throughout the day.
Has anyone else had a similar issue? And of so, how was it rectified?
Threads: 5
Thanks Received: 51 in 39 posts
Thanks Given: 19
7
It only updates once every 100 miles, that is, you can travel almost 200 miles and still see that the servise counter has only dropped by 100 miles.
The following 1 user says Thank You to Buki for this post:1 user says Thank You to Buki for this post
• LukeC
Threads: 28
Thanks Given: 4
12
04-02-2024, 12:46 PM
(This post was last modified: 04-02-2024, 01:05 PM by LukeC.)
That seems a bit odd to me. Other ones I've had all did 50ile intervals. Although it doesn't explain why it showed 1150 as I parked last night, and 1050 this morning... It seems to take a while to update itself.
Sorry, it's gone from 1150 to 1100. So it is dropping in 50s. Just seems to only do it overnight though.
Threads: 19
Thanks Received: 31 in 30 posts
Thanks Given: 12
16
What happens if you drive backwards?
Now a 2019 K9 1.2 petrol.
Threads: 81
Thanks Received: 397 in 340 posts
Thanks Given: 166
21
(04-02-2024, 02:19 PM)Mark604 Wrote: What happens if you drive backwards?
Insurance gets more expensive
Thanks Received: 2 in 2 posts
Thanks Given: 1
It also depends on time
My did about 7 thousand kilometers and it ask for service
I checked and it passed 1 year from last service
every month it drops more than i run
Threads: 81
Thanks Given: 166
21
If it's a worry then reset the timer
