ABS ecu module replacement.
I have an ABS module fault and am looking at replacing the abs ecu module rather then the whole abs unit.
Am I able to fit any similar ABS unit or should I be looking for certain numbers to match. My current number on the module is 6 443 L3 280114 085.
I had ABS on my 61 Berlingo, £500 for them to take off send away and replace, over a week time no car.
New I believe is about £1,000 plus fitting.
May need code reset after.
Hope this helps, mine was sent away and lost, took 2 weeks to get my car back.
Your Reach is further than your Grasp
(03-02-2024, 01:05 PM)Fimbish Wrote:  I have an ABS module fault and am looking at replacing the abs ecu module rather then the whole abs unit.
Before you go changing the whole module, what is the fault code you are getting to make you think the ABS module is at fault?
_______________
Not a Citroen  Cry
2008 B9 1.6Hdi Multispace XTR
2002 Xsara Picasso 2.0Hdi
1996 ZX 1.9TD Estate
As above - how was that conclusion reached? There are other, simpler faults that can cause ABS problems.
As for replacement - I'd probably replace with a good used unit rather than spending £hundreds on an electronics rebuild.
Newbie
Last Post: DannyWxM
Today 07:39 PM
Thermostat Overheating, Radiator Cool
Today 07:34 PM
Oil consumption at 200K miles
Yesterday 12:47 PM
21-05-2025 06:54 AM
20-05-2025 09:42 AM
» Replies: 54
Last Post: rnamman
19-05-2025 02:03 PM
Last Post: allanr
18-05-2025 05:57 PM
Forum activity
17-05-2025 06:32 AM
Emissions fault.
11-05-2025 06:29 AM
10-05-2025 05:31 PM
