Hi all,
I have a 2018 75hp with 140k and was serviced 10k ago, yesterday I was driving home from work which is a 10 min drive on a dual carriage way so was up to operating temp, I slowed down as I was pulling into my local Asda when I looked in the mirror and saw a cloud of smoke following me, the smoke was pluming out at low speeds and was still coming out at idle until it sat for about 30 seconds, however when revving it chucked out white smoke again but not at every rev.
The coolant level hasn’t dropped so I’m hoping it’s not the head gasket. Could I be looking at a set of injectors? If so do they need coding in?
It has developed a slight almost aggressiveness when firing into life when starting, it’s hard to explain but I just put it down to being cold.
Any suggestions would be appreciated
Thanks Paul
Thanks Paul
