Threads: 6
Thanks Received: 1 in 1 posts
Thanks Given: 4
Every morning I have to manually bleed the fuel system a few seconds after it starts okay and then peters out. Once it is bled then it runs perfectly well throughout the day without issue. I've had the injector leak-off pipes replaced and new pipes fitted around the fuel filter and to the injection pump but the air continues to get in after sitting overnight.
Any suggestions?
Cheers.
Threads: 43
Thanks Received: 416 in 373 posts
Thanks Given: 139
33
Highest point in the fuel system is the fuel filter lid, common for them to leak air into system there with no sign of fuel leak.
Anywhere lower than that show as a slight fuel leak and overnight will let the fuel run back into tank.
2020 Rifter 1.5 allure
2010 B9 red XTR w a v.
2001 1.9d DW8B white Berlingo
2005 2.l green Berlingo
berlingo 1.4 red multispace
1993 xud 1.9 red partner
