Bluetooth microphone sound quality
Hi
I upgraded my stereo to RD45 to add USB and Bluetooth calling using a used kit from eBay
Installed OK microphone in factory fitted position overhead near interior light
Calls work well but people say sound quality is bad on there end, tinny and distant
Any ideas why this is or how I can improve outgoing sound quality
Cheers
I have the system in my van from new and my microphone is on the A pillar so a lot closer to your face,
B9 Berlingo enterprise 625 blue HDI (9HN) 75hp
[-] The following 1 user says Thank You to swawp for this post:
  • shawstvs1
Mine came factory fitted at the top of the A-pillar. Velcro attaching it to the soft liner. The only person who has mentioned anything is my old man, who says, and I quote "Sounds like you're shouting in a biscuit tin". I'm not sure if it makes any difference that he's using WhatsApp to call as he lives abroad and that makes it a lot cheaper. People on normal mobile or landline systems haven't complained about quality, one did say it sounded like I was driving (he was right).
[-] The following 1 user says Thank You to LukeC for this post:
  • shawstvs1
Used original kit I bought came with mic that clips into place in bulkhead suppose I could have velcroed it to A pillar
See how it goes I think
Cheers
i have rd45 with mic in the original ceiling position, no problems and no complains Smile
If you like gaming visit GameForest
Right OK
I had to route cable through dash and up A pillar to bulkhead but that's way they are usually routed so don't think any issue with interference
Maybe try replacing mic with a newer used one it can unclip from connector near mic end and just replace that
Worth a try maybe
Cheers
Engine Fan Running
04-12-2025 11:07 AM
Last Post: SonofaGun
02-12-2025 10:51 PM
02-12-2025 06:14 PM
Rear view mirror
02-12-2025 08:19 AM
Gear number display
Last Post: MarcoLingo
29-11-2025 09:02 AM
25-11-2025 04:20 PM
Lapik's 5-th Berlingo
25-11-2025 08:21 AM
ë
24-11-2025 09:08 PM
Welding precautions
24-11-2025 12:37 PM
driveshaft tripod joint spring
24-11-2025 12:31 PM
