08-02-2024, 08:40 PM
2011 B9 1.6 HDi 62,000
Issue: grey smoke from exhaust all the time.
Diagnosis (so far):
Otherwise runs fine, good performance, steady idle
Oil level normal - not using any nor adding to the level
No fault codes on OBD reader
No back pressure on DPF (was cleaned in October last year)
No air intake leaks
Turbo is fine
Last 3 refuels have been with Premium diesel. A bottle of Forte Diesel cleaner was added in December and again in January. Two weeks ago Forte Injector cleaner was added along with 20 litres of Premium fuel.
Has me and now the local garage foxed.
What is left to check?
Blocked air filter or fuel filter?
Compression test although oil consumption is nil between services?
The car's mileage over the last couple of years has reduced dramatically with much fewer motorway miles and more local mileage resulting in the DPF becoming blocked last year. It's been serviced annually, including oil and filter change, irrespective of mileage.
Really grateful for any ideas or suggestions as to what it may be. Thanks.
Diagnosis (so far):
No air intake leaks
Turbo is fine
