I have a permanent airbag light showing and my Red OBD is showing Fault Code B0079 "Incorrect LF/Driver SIS Installed". I assume LF means Left Front and SIS means "Side Impact Sensor". I also assume the word "Driver" is only applicable to LHD cars as Code B0081 refers to "Incorrect RF/Passenger SIS Installed". The fault light has only recently appeared so the SIS would be the original correct fit.
I have disconnected and spray cleaned sensors under the seat, on the SIS (both sides), the drivers seat belt pretensioner and both the seat belt reel pretensioners and replaced the left side SIS (part number 9810452480) with a new one with the same part number. There has been no change to the airbag light or Fault Code. I have cleared the codes but B0079 comes back immediately.
I am now puzzled as to what to do next.
Has anyone else seen Fault B0079??
