ico2 connector
Further to my thread re glow plug relay fault, I've read on here that it can be caused by corrosion in the ico2 connector but although I know where to find it, I cant for the life of me either find it in the manual or understand how to pull it apart to check it.
Could somebody advise please.
[-] The following 1 user says Thank You to zaskar for this post:
  • evdama
Hopefully, this one is now sorted.
I've taken a couple of weeks to post cos with my luck, it always goes that I post it's sorted and the very next day.................
Anyway, in desperation, I managed to get the IC02 connector apart and had a good look inside. TBH, I couldn't see anything obvious, no busted pins, no corrosion etc.
I sprayed both parts of the connector in WURTH 2040 which I've found to be fantastic stuff for dodgy electrical connections in the past.
We're now over 2 weeks down the line and the little fella has started 1st time, everytime on the button.
HTH
  • brodfather11
Thanks for letting us know
2020 Rifter 1.5 allure
2010 B9 red XTR w a v.
2005 2.l green Berlingo
berlingo 1.4 red multispace
1993 xud 1.9 red partner
Yesterday 04:12 PM
Yesterday 12:46 PM
Yesterday 10:00 AM
Last Post: RMSSA
22-09-2026 08:52 AM
Turbo lag 1.6HDi
Last Post: Westy
21-09-2026 09:07 AM
removing front strut
16-09-2026 02:07 AM
