  • 8 Vote(s) - 3 Average
1st Berlingo
[Image: DSC_0080.jpg]
picked up my first Berlingo last weekend.... Mk1 1.9 diesel multispace.
The pope-mobile (last owner was a vicar!) will eventually be a weekend camper for kayaking trips.
So far I've wired in a string of 70 white led lights to the interior lights (lovely and bright in there now when i open the door) and some blue led mood lighting on a switch on the shelf above the dashboard. Tinting the rear windows and making some curtains in the next few days...
Any comments or tips will be appreciated
Russ
Hi and welcome along Russ. Some pics of your interior mods would be really nice.
Have you looked at getting the tinting done professionally? Because its not always that expensive, but it is a pig to get right (assuming you havent done it before!)
P.s I tried fixing your image link because it doesnt look to be working my end, try re uploading your pic to http://www.uploadvillage.com
the led strips are rubber coated, i've just used the plastic trim above the doors to hold them in place.
I was quoted £160 + vat to get the windows tinted... think that's a bit pricey to be honest. I'm off to Devon kayaking next weekend so it's going to be an evaluation weekend for what my requirements for camping will be.
My only criticism of the car so far is that the drivers seat seems to sit fairly low in the car, i've been used to sitting quite high up in the past. The foam in the seat is quite worn so the seat could do with replacing anyway.
I uploaded the pic with the tinypic link
Welcome Russ. Wouldn't mind seeing how the LED's are in place. Good to have you here
Lliam
Lliam
70 plate Berlingo
WELCOME rUSS
Hi Russ and welcome to the forum
Hi RUSS i HAD MY WINDOWS TINTED TO 25% AND dont need curtains as you cant see in , unless you put internal lights on. Saved all the bother of curtains. BUT I can see out really well. I considered actually converting both professionally and me doing it, but decided in the end to keep it simple, a work box on wheel inside with cooker etc in, this doubles as a seat if taken out, and allows everything to come out if two of us want to sleep in back. with seats taken out.
Pete.
Hi pch,
what you describe is what i've got in mind. Keeping it simple is deffinately my moto!
How much did your windows cost? I still like the idea of curtains, makes it feel a lot 'warmer' and cosier inside with curtains. Hoping to knock up something simple on either curtain wire or some studs of somesort (been down fabric-land today and seen some nice (cheap) material that goes well with the colour of the car)
Had a look at some temporary conversions on the net, and when (if) it stops raining, going to get out there with a tape measure and try to work out the best way of constructing a make-shift bed.
yes I thought of a bed at first as well, but instead opted for the self inflating mattress thingys as it can all be moved around, and in and out as needs arise.
Be good to see your thoughts.
I did consider taking one or two seats out permanently and fitting a bed [single] with storage under and a hinge up top bed, but decided in the end not worth it as my van has to be multifunctional.
08-10-2026 07:24 PM
06-10-2026 12:46 PM
06-10-2026 10:00 AM
Last Post: RMSSA
22-09-2026 08:52 AM
Turbo lag 1.6HDi
Last Post: Westy
21-09-2026 09:07 AM
removing front strut
16-09-2026 02:07 AM
