intermittent right indicator problem
Totally random, happens in all weather conditions. Sometimes woks perfectly.
left indicator works properly all the time but indicate right but the left might come on instead, not good on the motorway.
Any ideas please
1.6 multispace HD 2009
2009 1.6HDI with AC
I'd be having a good poke around the indicator stalk as a starting point.
(02-03-2024, 02:46 PM)magoo1 Wrote:  Totally random, happens in all weather conditions. Sometimes woks perfectly.
Any ideas please
As has been stated in the previous reply from @shtu start with the indicator stalk, take off the steering wheel surround [from memory there are three torx head screws to undo] and then access the switch. Try spraying some electrical contact cleaner such as servisol on the electrical connector and into the switch. Do NOT use WD40 or such like as that can leave a residue that can cause electrical problems.
_______________
Not a Citroen  Cry
2008 B9 1.6Hdi Multispace XTR
2002 Xsara Picasso 2.0Hdi
1996 ZX 1.9TD Estate
thanks, took my can of electrical contact cleaner and the spray pipe pinged off and too cold anyway.
2009 1.6HDI with AC
a squirt of compressed air down the stalk and got a straw fore the contact cleaner, got it inside and saturated the switch.
Done a few trips and not wishing to tempt fate problem solved.
thanks for all ideas.
2009 1.6HDI with AC
08-10-2026 07:24 PM
06-10-2026 12:46 PM
06-10-2026 10:00 AM
Last Post: RMSSA
22-09-2026 08:52 AM
Turbo lag 1.6HDi
Last Post: Westy
21-09-2026 09:07 AM
removing front strut
16-09-2026 02:07 AM
