Threads: 84
Thanks Received: 397 in 340 posts
Thanks Given: 179
21
03-03-2024, 03:36 PM
(This post was last modified: 03-03-2024, 03:36 PM by evdama.)
Had a seized one to free off this morning.
It put up a good fight but I eventually won.
I worked it with a ratchet turning backwards and forwards until it turned then put a blunt chisel under its head and pushed as I turned and it slowly came out.
Has anyone got a better way?
Threads: 39
Thanks Given: 1
4
No but make sure and the housing are spotless then lather it in copper grease when refitting
Peter
Threads: 84
Thanks Given: 179
21
(03-03-2024, 04:58 PM)Romahomepete Wrote: No but make sure and the housing are spotless then lather it in copper grease when refitting
Peter
Thanks Pete that's reassuring.
All the other pins were nice and free.
I polished the bad pin with a rotary wire bush and greased it to rake out the gummed up hole.
Cleaned it off again and repeated until I fell asleep.
Finally reassembled with some ceramic brake grease
It should suffice until the pads /disk need changing and then I'll put in new calipers and pins as well in all at once.
