Threads: 9
Thanks Received: 6 in 6 posts
Thanks Given: 32
Hi mates, how do i change the bulbs in the dashboard? Actually the odometer needle and background are dark and the rpm area is ok. Thanks in advance.
B9 XTR THEATRE 1.6 HDi 92 cv
ex M59 1.6 HDi
Threads: 41
Thanks Received: 408 in 365 posts
Thanks Given: 134
31
I dont think they have bulbs, think they are leds mounted onto the instrument panel.
The skodas have smd leds on the instrument panel which can be unsoldered and new ones soldered on , if the Berlingo ones are the same then it should be possible
2020 Rifter 1.5 allure
2010 B9 red XTR w a v.
2001 1.9d DW8B white Berlingo
2005 2.l green Berlingo
berlingo 1.4 red multispace
1993 xud 1.9 red partner
Threads: 27
Thanks Received: 19 in 18 posts
Thanks Given: 4
12
I think in my m59, and my xsara picasso (worst car ever owned) they were both bulbs, and needed a lot of work to get them replaced, so just got the whole lot done in one go, rather than just the dead bulbs.
I can't see why if they're LED that they would have gone this early in the vehicles life.
The following 1 user says Thank You to LukeC for this post:1 user says Thank You to LukeC for this post
• Metamatix
Threads: 67
Thanks Received: 716 in 613 posts
Thanks Given: 236
50
06-03-2024, 08:10 AM
(This post was last modified: 06-03-2024, 08:10 AM by geoff.)
I'd look on YouTube for a video or buy a Haynes manual for the procedure ( or both ).
Good luck with it you have my sympathy as I find dash removals a fiddly and frustrating experience.
Serieal Berlingo owner
• Metamatix
Threads: 9
Thanks Given: 32
(06-03-2024, 07:38 AM)fratellopadre11 Wrote: Non penso che abbiano lampadine, penso che siano led montati sul cruscotto.
Gli skoda hanno led smd sul cruscotto che possono essere dissaldati e nuovi saldati, se quelli Berlingo sono uguali dovrebbe essere possibile
Yep, it's my suspect too...
ex M59 1.6 HDi
Threads: 9
Thanks Given: 32
Finally I've changed the whole speedometer, I've found one from a Partner and luckily he had less mileage aof mine so he settled on my real numbers. Found at super price of 38 euro, works perfectly and also has the chrome rings decoration around the clusters which mine didn't had, so win-win ?, thanks everybody
ex M59 1.6 HDi
