Wiring to Driver's Seat Belt Buckle
THe wiring to my driver's seat belt buckle has broken very close to the buckle making repair difficult. I need to reconnect the wiring to the buckle but can see no obvious way of opening the buckle as the usual screws are not there. I guess the two halves must be glued together. Has anyone successfully opened a seat belt buckle on a Berlingo?
(08-03-2024, 04:19 PM)Cumbrian Wrote:  THe wiring to my driver's seat belt buckle has broken very close to the buckle making repair difficult. I need to reconnect the wiring to the buckle but can see no obvious way of opening the buckle as the usual screws are not there. I guess the two halves must be glued together. Has anyone successfully opened a seat belt buckle on a Berlingo?
A big flat head screwdriver and some courage. It will come apart. I had to open mine to transplant into my Range Rover seats I fitted.
I managed to repair mine (without opening the buckle up) with some very small crimp connectors reinforced with a blob of solder and covered with two layers of heat shrink tubing. I then secured the wires with cable ties.
It would apear that mine wasn't an isolated incident but I don't understand why the wires should break in this way.
(23-06-2024, 02:02 PM)Cumbrian Wrote:  I managed to repair mine (without opening the buckle up) with some very small crimp connectors reinforced with a blob of solder and covered with two layers of heat shrink tubing. I then secured the wires with cable ties.
Where they exit the buckle ( as you'll be aware ) there's a tiny cable tie from Factory then an inch or 2 of metal stem before the really heavy duty French securing idea comes into place, electrical tape eh!
Side Light Bulb Holder
14-01-2026 07:58 PM
ASDA AdBlue 10 January 2026
13-01-2026 07:04 AM
Last Post: andy@andymcm.com
12-01-2026 01:47 PM
» Replies: 24
Sticky throttle
Last Post: knucklerash
11-01-2026 05:53 PM
10-01-2026 07:54 PM
Last Post: jippo
10-01-2026 05:39 PM
Fuel cooler and hoses
08-01-2026 08:00 PM
Last Post: uk_friendly_fire
07-01-2026 06:51 PM
» Replies: 37
06-01-2026 10:38 AM
05-01-2026 06:05 PM
