Dreaded front end knocking x2
Hi all,
So I unfortunately have the dreaded front end knock but I have two different knocks, one of them is a slight vibration knock at around 1500rpm and over uneven ground and sounds like it’s coming from the passenger side, the second is like a hard knock when letting off the throttle more of a clunk and more middle sounding but does sometimes feel like it travels and comes from either side and only just started but both are driving me nuts!
After doing some research I’ve replaced a few items such as,
Both lower arms
Drop links
Top mounts
I looked this evening at the gearbox mount and it doesn’t look perished or anything but does feel soft but not sure if that’s standard,
I feel like the clunk could potentially be the rear engine mount however looking at it, it didn’t look worn.
Does anyone else have any suggestions
The good thing here is that the parts are really cheap. Just as well, because they don't half chew through stuff.
For suspension bits, both Febi and Meyle are hlaf decent and cheap if you shop around a little.
(15-03-2024, 09:22 PM)iipaul Wrote:  a slight vibration knock at around 1500rpm and over uneven ground ... I’ve replaced a few items such as,
Both lower arms
Drop links
Top mounts
You could take a look and make sure the droplinks are still tight, and check the lower balljoints, and anti-roll bar bushes.
(15-03-2024, 09:22 PM)iipaul Wrote:  a hard knock when letting off the throttle more of a clunk and more middle sounding but does sometimes feel like it travels and comes from either side and only just started but both are driving me nuts!
I'd swap the bushes in the lower engine mount. It's on the list for mine, as it's got a fair old dose of driveline shunt.
I had a front end 'clunk' on my Berlingo B9 Multispace and went through all the items you list, plus after talking to my MOT chap who carries out my MOTs asked him if he has spotted anything [it was still passing MOTs without any problems] he stated that he has noticed a bit of play on the inner track rod ends but didn't think that would be the cause. AS I had tried all the obvious stuff, I replaced these [even bought the correct tool for fitting them] but I still had the clunk, so that wasn't the problem
I asked on this forum listing everything I had tried and got a reply from @Lighty [who used to be a regular contributor on here. He ran an independent car workshop that specialised in French vehicles but he sadly passed away a few years back] Anyway, he suggested from Berlingos he had worked on with mysterious knocks/clunks before that I replace the front shock absorbers, as he had seen a number where that had been the cause. I was a bit sceptical as I had already had them out to replace the top mounts and they seemed fine to me but having come to a bit of a dead end I replaced them both and no more clunk! On checking the old ones they didn't seem to have that much lateral movement of the piston but it was obviously enough to cause the problem in my case.
So that's one possibility.
_______________
Not a Citroen  Cry
2008 B9 1.6Hdi Multispace XTR
2002 Xsara Picasso 2.0Hdi
1996 ZX 1.9TD Estate
My B9 had a loud clunk on suspension rebound at front. I suspected right corner. It was unbearable on rough icy roads on winter. MOT inspector did not find anything although I specifically requested to search for play.
As it was not the droplinks, I replaced the front shocks plus top mounts. There was no obvious fault visible on the old parts, but the clunk was gone. Ah what a relief.
Thanks for the replies,
So I had it in the garage today and they actually said everything is solid the only thing they suggested was to replace the shocks and maybe worth doing the gearbox mount as they’re cheap enough,
I just hope it is the shocks as it’s horrid to drive feels like it’s going to fall apart lol
Just to confirm the suspension was the cause of my knocking, the front left strut rod had about 4mm movement back and forth which was causing some annoying knocks!
Glad it’s fixed, thanks for the replies
[-] The following 2 users say Thank You to iipaul for this post:
  • Drummond, Harrythephot
(21-03-2024, 09:56 PM)iipaul Wrote:  Just to confirm the suspension was the cause of my knocking, the front left strut rod had about 4mm movement back and forth which was causing some annoying knocks!
Good to see you got it fixed and for posting the cause in your case, as it's always useful to other readers to know solutions to problems.
_______________
Not a Citroen  Cry
Just to add, this is a common issue on the K9 2018- onwards Berlingo
Lots of people reporting clonking suspension noises
Solutions vary
One thing we can all agree on, these vehicles on average go through drop links every 2 years
Diagbox 9.91 free download
Last Post: Slowmo
Yesterday 06:29 PM
Last Post: Slowmo
Yesterday 06:26 PM
» Replies: 29
07-02-2026 05:42 PM
heater down
05-02-2026 04:49 PM
Rear seat belt breakage
02-02-2026 02:34 PM
High mileage vehicles ?
Last Post: chrisl
01-02-2026 09:22 PM
Berlingo rear suspension
Last Post: Geordie graham
01-02-2026 01:13 PM
Last Post: chrisl
29-01-2026 07:06 PM
28-01-2026 09:18 PM
Cheap(er) oil
28-01-2026 03:39 PM
