18-03-2024, 06:17 PM
My 2017 1.6blue hdi van has been doing some odd things.....
I had the orange triangle on a couple of thousand miles ago, I refilled the eolys tank which was empty and reset via diagbox, all good I thought.
Now the mpg had dropped to 47mpg from 53mpg, over this time and still didn't improve, the last tank it went back to 53mpg then the orange triangle came on again at the next fill up and it's dropped back to 47mph.
So the codes were pointing to an eolys pump leak, and lack of communication.
Today I inspected the tank, no leaks at it or in the lines, I reset again via diagbox and it primed itself for 10minutes this time, then all good, triangle gone etc etc.
However, when I scanned for codes the dreaded P242F particle filter worn code came up....but no engine or triangle light???
Checking actual measurements, a regen occurred 270km ago, it's calling for a regen, soot loading was 5grams, and differential pressure was 2 and 18mbar at idle/3000rpm which might be a bit low??
Any suggestions? As i said there's no light on.
Now, I've noticed the glowplug light doesn't come on at any time now, coincidence?
Some others range things is that I've a passenger airbag deactivation switch led code 7362 - has it got one?
