injector plastic neck broken
injector 4 (far right) the man from the AA spotted it straight away, the orange plastic bit is broken away from the top of the injector, fuel spraying out and once engine up to operating temp gives a nice dry ice effect :Smilet is just floating above the injector
Just had a service done so bad coincidence, back to garage Monday. can just the orange bit be changed?
don't know why image isn't showing?
2009 1.6HDI with AC
I've tried all I can think of to post image to no avail
changed from tiff to jpeg size is 120 kb
2009 1.6HDI with AC
https://tinypic.host/image/IMG-20240323-...opy.DG4Sjm
2009 1.6HDI with AC
tinypic living up to it's name there. Big Grin
From a CSI-Miami style ZOOM! ENHANCE! session against all 4 of those pixels, it looks like the leakoff fitting has snapped, oring failed, something like that.
A new leakoff pipe assembly isn't expensive. eg, first example I found, https://injectionpumps.co.uk/product/inj...injectors/
Complete leak off pipes are cheap on eBay - bought one last October for less than a tenner delivered !
It's a quick and super easy job to fit one - a very lazy ten minutes will see you sorted
thanks for the replies.
if its snapped how do i get get the broken bit in the injector out?
2009 1.6HDI with AC
The type of approach I have used for similar situations in the past is to drive a screw into the plastic, and pull it out with a pair of pliers. It won't be a massively tight fit in the injector.
I've no idea if this will work in this situation, use your own judgement.
Obviously, get the retaining clip out of the way first. Ignore the red square, look at the spring cliip on each injector.
[Image: 2014-10-14-15-02-12-jpg.23018]
in the garage £70 for part.
2009 1.6HDI with AC
Last Post: BDRichardson
Today 04:07 PM
Yesterday 09:56 PM
04-09-2026 05:28 PM
Last Post: kulat
03-09-2026 09:59 PM
31-08-2026 08:50 PM
29-08-2026 08:39 PM
29-08-2026 08:26 PM
29-08-2026 05:45 PM
24-08-2026 07:58 PM
23-08-2026 06:25 AM
