Threads: 3
Thanks Given: 1
27-04-2012, 09:34 PM
(This post was last modified: 27-04-2012, 10:38 PM by godfathertre.)
rear wiper motor not working i took rear panel on back door checked all wires going to unit there is not power, can anybody point me to the right fuse box looks like a minestrone i checked some if not all fuses the seem okay ,vehicle is berlingo 2001 multispace thank you.
Threads: 13
Thanks Received: 23 in 18 posts
Thanks Given: 31
Hi
I think you will find the fuse is 15 amp Blue in the secondary fuse box ( Built in systems interface ( BSI ) unit/fusebox ) below the passenger compartment fuse box according to Haynes ( Not looked myself cause its cold and dark out there at the moment ! )
If that fuse is ok then it could be a break ( due to metal fatigue ) where the cable runs through one of the two rubber shroud/grommet that connect between car body and the tail gate ( They carry cables for numberplate lights, heated rear window, high level brake light, rear wiper, and water tube for rear wiper wash. ) and flex of course every time you open or shut the tailgate.
Hope this helps to get you started down the road to fixing it, sure others with better knowledge will help further
