Dripping water
Any idea why water drips from under the car when it's parked on a slope? This is from the driver's side about the middle of the sliding door. The water isn't coming from the door itself, it's about 4 or 5 inches in from the sill.
Put up a photo.
I suppose if at least its draining its better than if it stayed trapped.
Do you have the Aircon running, and only noticed the condensation drips when it's on a slope? Sorry for exploring the simple items to rule out first. But my mind has a logic system I can't shut off, always starting with ludicrously obvious things.
[-] The following 1 user says Thank You to LukeC for this post:
  • Arfcollins
https://tinypic.host/image/IMG-20240408-...300.DhQ29v
Was the vehicle wet when you parked it, or did condensation occur while it was parked overnight?  It's surprising how much water can drain off the paintwork.  My old M49 is usually parked with the driver's side on a kerb, and even after just a dewy morning there's often a big damp patch on the road under the passenger's side, sometimes even trickling away halfway across the road.
[-] The following 1 user says Thank You to notsofast for this post:
  • Arfcollins
There's a device underneath in that area with cooling fins on it..
Might be that.
  • Arfcollins
(08-04-2024, 01:42 PM)evdama Wrote:  There's a device underneath in that area with cooling fins on it..
Might be that.
Aha! I looked at Haynes and it turns out that I have a fuel cooler. I thought my fuel was pretty cool already, but presumably there is a good reason for having it.
(08-04-2024, 01:24 PM)notsofast Wrote:  Was the vehicle wet when you parked it, or did condensation occur while it was parked overnight?  It's surprising how much water can drain off the paintwork.  My old M49 is usually parked with the driver's side on a kerb, and even after just a dewy morning there's often a big damp patch on the road under the passenger's side, sometimes even trickling away halfway across the road.
None of those things was causing it, but thanks. See Evdama's reply.
(08-04-2024, 12:26 PM)LukeC Wrote:  Do you have the Aircon running, and only noticed the condensation drips when it's on a slope? Sorry for exploring the simple items to rule out first. But my mind has a logic system I can't shut off, always starting with ludicrously obvious things.
Thanks, but I have no aircon. Evdama solved it.
You're welcome anyway! I was also envisaging a forward or backward slope, rather than sidewards, which when I saw sidewards, it already put pay to my suggestion!
Yesterday 11:13 AM
Last Post: TGD
06-06-2026 09:50 PM
06-06-2026 12:29 PM
Last Post: CB-K9murph
05-06-2026 05:47 AM
03-06-2026 06:47 PM
Fuel pump problems
02-06-2026 07:07 PM
Last Post: Desdinova
27-05-2026 10:15 AM
Last Post: Stevie3393
25-05-2026 12:34 PM
24-05-2026 12:57 PM
Rattling calipers
Last Post: Chrisfox1975
24-05-2026 10:47 AM
