[Engine] Fuel pressure regulator lexia
Hi
Would anyone know why when I test the fuel pressure regulator with lexia it does not vibrate. I replaced it and it still didn't vibrate. I applied 12v directly to both on a bench and neither clicked in or out. Could I have brought a brand new dud.....£60.
I don't want keep throwing £60 away trying to solve.
Many thanks
(08-04-2024, 12:20 PM)Kc1979# Wrote:  Hi
Many thanks
While it's possible that you've bought a dud unit, it does seem strange that both old and new items don't click when voltage applied? What is the actual p/no of the item you are testing/trying to replace? What is the fault with your vehicle that led to to that component?
_______________
Not a Citroen  Cry
2008 B9 1.6Hdi Multispace XTR
2002 Xsara Picasso 2.0Hdi
1996 ZX 1.9TD Estate
Hi
Thank you you for your response.
Part number is A2C59506225  2.0hdi siemens system
The symptoms was going into limp mode under full load, but very intermittently, the van drove fine and idles well. It threw no codes from what I can see? The limp mode clears on its own after about 20 mins???
I was just paying with lexia when I found the option to test the fuel regulator  (no vibration) and the other item did vibrate, I forget its name but next to the fuel regulator.
That fact the fault only happens I'm certain conditions makes it hard to pin point. I prefer it when things just break with a big bang, you know where to look then lol.
Attached Files Thumbnail(s)
Hi
Haven't had much experience with the 2.0Hdi engine [which is different to the later 1.6Hdi] but the 2.0Hdi is normally a lot more reliable [I had the 2.0Hdi is my Xsara Picasso in the past and it never gave any problems]
From what I've seem on this forum, the most likely culprits are the EGR valve and the MAF sensor. The EGR valve on the 2.0Hdi is a purely mechanical affair and there have been reports of the sticking open and MAF sensors have been know to give problems on all models.
Reading through this thread might be of some help: https://www.berlingoforum.com/thread-22017.html
_______________
Not a Citroen  Cry
2011 B9 DPF warning light
Today 11:22 PM
Any advice regarding boot carpets being wet!?
Today 05:50 PM
» Replies: 21
Today 10:53 AM
Frequent DPF REGEN's
Yesterday 08:43 PM
Power Steering gone - reservoir full, hoses and ...
Last Post: Collapsedsuspension
Yesterday 02:29 PM
Power flex anti roll bar bushes
Last Post: NANO_Vigo
Yesterday 10:54 AM
Power flex lower wishbone bushes
Last Post: AD246
Yesterday 08:54 AM
How to change your username
Last Post: Mike
16-01-2025 11:04 PM
Spot the Berlingo(s)
16-01-2025 12:20 AM
knocking from rear
15-01-2025 04:59 PM
