Threads: 7
Thanks Given: 9
Hello again.
I have a problem with the air filter lid. The torx socket has rounded (on the right hand side) but all the others are out. The garage that I use say that they need to remove the wipers and then the plastic scuttle to gain access to remove the box and then drill the screw out. This sound drastic and an expensive fix with labour at £50 and hour!
Has anyone had this problem and has anyone any ideas for a method of doing it myself? I know from past Vectra experience that removing wiper arms that have never been off since a car leaves the factory is a world of pain I would rather avoid.
Thanks in advance.
Threads: 7
Thanks Received: 11 in 4 posts
Thanks Given: 13
I've just had a look at mine and can't see why they'd have to do all that work ?
The air box only has 3 x screws in the front which all look accessible on mine..
I'd probably 1st try to knock the screw around (anti-clockwise) with a screw driver or small sharp chisel until far enough out to get a pair of pliers or grips on it, if that didn't work you could maybe get a battery drill in on an angel and drill most of the Torx head off, you'd definitely get in with a Dremel tool or similar small grinder.. Worst care scenario look for a cheap replacement cover on eBay then just use a bit of brute force to get the old one off, probably be a lot cheaper than using a garage..
If you can't do it yourself, I'd be trying another garage as the one you've been to are either easily beat or taking the p@ss..
2013 B9 16HDi Multispace Kyanos Blue (Plan to Camperise)
Threads: 80
Thanks Received: 378 in 321 posts
Thanks Given: 162
14
Dremel could turn the torx head into a slot head then use a screwdriver to get it out.
If yours is the same as mine 8v 1.6hdi then it sounds like that garage is full of sht.
Three screws at the front and a clip on the right hand side
• sciteacher
Threads: 12
Thanks Received: 28 in 23 posts
Thanks Given: 1
Hi
Remove the air box is a pain in the a...... I did. But for 50£ I will pay very happy.
I did not removed the wipers, I will recomend to anybody removed the wipers.
My Berlingo 2009 with the old box is the hell.
Vigo, The cradle of all Berlingos / Partners.
