Threads: 26
Thanks Received: 19 in 18 posts
Thanks Given: 4
12
I've removed a number of stickers from the windscreen of my van (ex hire vehicle - stickers denoting speed limits, no smoking, and a QR code with links to emergency contacts for the firm). The last one has been the worst for leaving a lot of residue, the no smoking one left a little. I can't find anything that wants to remove the worst residue at all, are there any folk here who have a good solution?
Threads: 18
Thanks Received: 24 in 24 posts
Thanks Given: 36
Brake cleaner usually gets anything like that of.
Threads: 40
Thanks Received: 77 in 70 posts
Thanks Given: 129
9
Tar & Glue Remover?
Threads: 78
Thanks Received: 363 in 306 posts
Thanks Given: 159
9
Isopropryl alcohol will shift most things.
Threads: 78
Thanks Given: 159
9
Probably an ingredient of it
Not in an aerosol it would be cheaper per ml
Have a look on eBay
It leaves no trace of itself so is useful for other things too
I tend to buy in larger volumes from APC for other purposes.
Not sure brake cleaner or carb /injector cleaner
would be paintwork/plastic/rubber friendly?
Threads: 26
Thanks Given: 4
12
I've tried to attach a photo of the issue, however, it doesn't want to work. There's only the one bit which is really needing attention. I think if it's liquid cleaner rather than aerosol, then I will apply it from a rag to ensure no drips and damage to the dash.
