  • 7 Vote(s) - 3 Average
LED Running Lights
A while ago I bought some of these LED strips to use on my motorbike, but never got around to it:
http://www.ebay.co.uk/itm/New-24cm-24-LE...144wt_1110
Today, after wiring up my towbar, I noticed that the gap underneath the headlights looked just about the right thickness for these LED strips so dug them out of their box.
Sure enough the LED strips are a nice tight fit between the bottom edge of the headlight and the top of the bumper; no other fixing would be required. I put one in and wired it up the battery. It was a bit bright here today but I think you can see the strip under the headlight.
Does anyone know of a switched live wire anywhere near the headlights that I could wire these up to?
Looking good
If you are going to use them as Daytime Running Lights then they have to be wired so that they are only on when the ignition/engine is on.
They must be off,or dimmed,when sidelights and,or headlights are on.
There are various cheap relays available on ebay for this purpose.
2010 XTR in black with bells and whistles
[Image: 5A50i.jpg]
[-] The following 1 user says Thank You to XTR for this post:
  • jericlin
Today 08:32 AM
Today 08:16 AM
03-03-2026 06:17 PM
03-03-2026 05:08 PM
03-03-2026 07:57 AM
02-03-2026 02:51 PM
02-03-2026 02:14 PM
Amdro boot jump for sale
Last Post: YTC1
28-02-2026 09:48 PM
Last Post: Muppets on Mars
27-02-2026 01:57 PM
26-02-2026 07:20 PM
