wiper motor replacement
hello
can anyone tell me how to remove the front wiper motor from my 07 berlingo 1.6hdi
thanks
access is from under the cover in front of the windscreen .
Remove wiper blades and arms, remove the panel which is in two parts left and right. The motor is there with the wiper linkage. Dont need to take out the linkage it should unbolt from the motor.
2020 Rifter 1.5 allure
2010 B9 red XTR w a v.
2005 2.l green Berlingo
berlingo 1.4 red multispace
1993 xud 1.9 red partner
thanks for your reply, i have changed motor now , but still it does work corectly
when wipers turned on to stesdy wipe it will do about 6 wipes across window an then stops in random positions .i then haveto turn switsh off an then on again to do the same thing it dosent matter if it is single speed or double speed or wash wipe it still does the same,is it possible that this is a relay or a switch problem
thanks for your help
Last Post: rom4ik
Today 04:11 PM
Side Light Bulb Holder
14-01-2026 07:58 PM
ASDA AdBlue 10 January 2026
13-01-2026 07:04 AM
Last Post: andy@andymcm.com
12-01-2026 01:47 PM
» Replies: 24
Sticky throttle
Last Post: knucklerash
11-01-2026 05:53 PM
10-01-2026 07:54 PM
Last Post: jippo
10-01-2026 05:39 PM
Fuel cooler and hoses
08-01-2026 08:00 PM
Last Post: uk_friendly_fire
07-01-2026 06:51 PM
» Replies: 37
06-01-2026 10:38 AM
