Adding heated seats to a k9
I have a k9 (combo)
Has anyone swapped their seats for heated seats
I see the switch is built into the seat, anyone know if the loom has the heated seat loom all ready?
I don’t want to bodge stuff, ideally just a swap of the seats
2022 LWB 1.2 petrol auto combo life (AKA Berlingo K9)
I'm planning to install the elements under a good close fitting seat cover (fake leather/alcantara) and wire into the back of the 12v socket that I don't currently use. I'll probably put the switch on the side of the seat on the plastic trim, there's a little square mark where I assume the factory heater controls are installed.
Local builder has done the same
Got a cheap heated seat pad from eBay, got a decent seat cover and placed the pad under the seat cover, powered by 12v lighter socket.
(24-04-2024, 07:24 PM)ComboLifer Wrote:  Local builder has done the same
Thanks for that, gives me confidence I'm not about to do something daft.
Cheers
(24-04-2024, 04:28 PM)Daddypig Wrote:  I see the switch is built into the seat, anyone know if the loom has the heated seat loom all ready?
Have a look under the seat and follow the airbag loom to carpet. I would expect wire terminal there - and free connector for heated seat power supply, if lucky. Maybe someone with OE heated seats could provide reference picture?
K9 wiring diagrams are not that easily available, unfortunately.
Thanks, that’s the plan. Must look into it some more
Rear door filling with water
Yesterday 06:56 PM
MOT Emissions repeated fail
Yesterday 06:53 PM
Last Post: rom4ik
20-01-2026 04:11 PM
Side Light Bulb Holder
14-01-2026 07:58 PM
ASDA AdBlue 10 January 2026
13-01-2026 07:04 AM
Last Post: andy@andymcm.com
12-01-2026 01:47 PM
» Replies: 24
Sticky throttle
Last Post: knucklerash
11-01-2026 05:53 PM
10-01-2026 07:54 PM
Last Post: jippo
10-01-2026 05:39 PM
Fuel cooler and hoses
08-01-2026 08:00 PM
